4" Components in Dash?? Single Sub boxes?
Car: 1987 L98 IROC-Z
Axle/Gears: 3.27 9 Bolt
As the title says, is there anyone running 4" components in the dash? I have Focal ES100K2's left over from my Chevelle that I want to make a plate for and run passive in dash. Rear speakers will be Focal ES165K2's also passive, Audiofrog GB2D10" Single Sub in the hatch. Amp is JL 1000Xi with DSP. The head unit needs to be changed, its a double din ebay knock off but will be upgrading.
I am also looking for a recommendation on a single 10" sub box thatll lay flat in the hatch well area. I would prefer the sub to be offset so I can put an amp on the other side but it doesnt have to be. Thanks.
Axle/Gears: 10 Bolt 2.73 Open
Re: 4" Components in Dash?? Single Sub boxes?
I added some Infinity 4" to the front of my T/A. Took a little work (modification) to clear an a/c duct, which may not be an issue on a Camaro. Details are HERE.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I have cerwin vega HED-1462P plate speakers and two 10" CW (free air, no sub box) in the trunk w/ two amps underneath.
