Sub box ? for pros
Old Jan 23, 2002 | 01:45 PM
82Trans Man's Avatar
Sub box ? for pros
To anyone who has any input. I searched and found a post with a ? about a square bass tube and Jim said that it would'nt make a difference. Now I am thinking of making my box. I only need .7 cubic feet. If the box top and bottom are close to the same size will I have problems with flex?? TIA
Old Jan 23, 2002 | 02:02 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
for the most part, the shape of a box in unimportant. as long as the internal size is correct (or as close as possible), and you use the correct wood (3/4" mdf is best), you wont have any problems. i dont see a .7 cu ft box flexing much if you use the right materials. if it does, try bracing it.
Old Jan 25, 2002 | 03:01 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I'm using a .625 cu. ft. sealed box made from 3/4" MDF on all sides and 1" MDF for the top plate. The inside is lined with fiberglass resin. The subwoofer cone will flex before the box does.
Pinguiclia
Oct 12, 2015 04:47 PM
86CamaroDan
Sep 29, 2015 10:08 PM
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
