"Common ground" Question
Old Apr 12, 2001 | 03:09 PM
jovialevil's Avatar
I have a question for all you car stereo nuts out there....OK I heard that you are supposed to use a common ground for your amps and your head unit so that you won't have ground loops in your system. Which means not using you factory harness....Correct? I keep hearing different $hit about this from everybody?? Could someone please clear this up so I can tell my buddies to stop smoking crack.
Old Apr 12, 2001 | 07:52 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
every electronic unit should be grounded no longer than 10" from the body somwhere. clean bare metal connections and dielectric grease are a good idea.
Old Apr 12, 2001 | 08:07 PM
Chris Luongo's Avatar
If you have more than one amp, try to ground them all at the same location, as close to the amplifier(s) as possible.
For the head unit, yes, what you've red is the "proper" method. Run a thick ground wire from the deck to the trunk, and ground it next to the amps.
Now, back to reality. I've been installing for a long time, and I've never had to run a new ground for a deck. Just ground it at the factory harness, and you'll probably be fine. If you do get noise after it's done, you can run a new ground wire then if you have to.
Old Apr 12, 2001 | 09:14 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Chris is right. Running the head unit ground all the way to the back isn't practical, and unless you use a very large gauge wire, it can actually create the problem you're trying to avoid (ground loop). In the very rare instance that you're getting noise through the deck, try running a 14 or 12AWG ground to the passenger kick panel area.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 13, 2001 | 12:32 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
On the radios in the systems I've done, I've also always used the factory power, memory, and ground from the harness.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 17, 2001 | 04:47 PM
88 GTA Notchback's Avatar
It's overkill dude. You shouldn't have a problem using the factory ground.
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT
88 Mustang GT
94? Impala (real close)
97 Dodge Neon
86 Corvette
2000 Prowler
And more Civic's then I can count. Why do they even bother?
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
