Anyone put amp in back storage area on left side?
Old Apr 10, 2001 | 09:10 PM
banks30's Avatar
I am talking about the where that little lock is at. There is sure a lot of space behind there. Just wondering
Old Apr 10, 2001 | 10:54 PM
matthew's Avatar
I'm sure you could put a small amp in there. But I plan to use it for when I get my CD changer.
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Old Apr 11, 2001 | 06:35 AM
cbpldc's Avatar
I put a little Punch 120 in there, and it worked fine, but it got really hot. Just make sure the amp you wanna put in there can handle heat well.
Chris
Old Apr 11, 2001 | 09:59 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
use an am with a built in fan.......say AUDIOBAHN or something
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
"Wise man once say, friends dont let friends drive Fords!!"
Old Apr 11, 2001 | 11:41 AM
banks30's Avatar
I will be putting in a Punch 60. I was thinking of taking off the little door and maybe covering with carpet so more air could reach the amp. Hey CBPLDC, how did you mount the amp? Thanks
Old Apr 11, 2001 | 11:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I put a Teac (Stop laughing, it pounded!) amp back there in a friend's car. Worked great except that his hatch leaked and for a while the amp was totally submerged in water. Oddly enough, it still works despite being totally rusted!
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 11, 2001 | 12:18 PM
cbpldc's Avatar
Banks,
I cut out the little carboard thingie and made a board that went from the top of the fender to the bottom and mounted the amp on that board and fastened the board with spray adhesive and velcro at the top and bottom, There are better ways to do this, but I wanted something stealthy yet not so permanent. The punch 60 is a good amp but they get really hot. I would mount a large fan to the inside of that locking lid, right behind the vents on the lid, and wire it to come on with your amp and pull the hot air out of there.
The reason I say to pull the hot air out instead of pushing the outside air in, is because the hatch will already be pretty stinkin' hot anyway.
Chris
Old Apr 13, 2001 | 02:27 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Teac made amps?????????
Stock 2.8 MPFI auto w/ Flowmaster 40, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Apr 13, 2001 | 03:56 AM
JP88RS's Avatar
I put my Alpine flex amp in there and mounted it to a piece of wood to keep it from moving.
Old Apr 13, 2001 | 12:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I had a Pyramid (do I hear more laughter?) amp back there. I had no cardboard storage box under the side lid when I bought the car. I made a board to hold the amp. I bolted one side down to the ledge left over from the hatch. For the rearmost leftmost corner, I made an aluminum brace that went from the bottom of the corner of the board up to the top of the "frame rail". There was a hole already there for me to use.
Then water got in there, fried the amp, yadda yadda...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 13, 2001 | 02:45 PM
FiReBReTHa's Avatar
so wheres all this water coming from?????
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Apr 14, 2001 | 12:09 AM
banks30's Avatar
My Punch 60 used to run at 1 ohm and it never got hot. I should probably consider a fan also though. Where abouts can I find one for cheap?
Old Apr 19, 2001 | 02:17 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
a lilsomthin i noticed. loose panel + poor weatherstip = plenty of mositure/weater in that well. rust proof hole in bottom = water leaving peacefully.
"Work like you don't need the money, love like you've never been hurt, and dance like you do when nobody's watching."
Old Apr 19, 2001 | 01:45 PM
CamaroZ_85's Avatar
yeah water does leak in there, and despite the litrtl drain hole some is bound to get on your amp so i'd find better places
Old Apr 20, 2001 | 08:46 AM
cbpldc's Avatar
I've never had water in there, but if it seems to be a problem, you can always seal around the panel.
Chris
Old Apr 20, 2001 | 03:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Turned out the bulk of my water was coming from the seal between the hatch glass and the rear fill panel (which the spoiler sits on). The rubber had shrunk with age and was letting water get in there- but then again, I even had water in the bottom of my hatchback. I bought a tube of Black Silicone (not RTV) for weatherstripping, and laid a new bead down.
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
