6 ohm dvc subs?
Old Apr 24, 2001 | 02:07 AM
FTC's Avatar
FTC
6 ohm dvc subs?
i was just looking at some dual 6 ohm voice coil subs made by ma audio. just curious how you would go about wiring these suckers. one, two, or even three?
Old Apr 24, 2001 | 02:23 AM
AmorgetRS's Avatar
It depends on the amp and what it is stable for....
Personally I'd wire them these ways:
1: wire them parellel to get 3 ohms
2: I can't even think of a way to wire these and get anywhere in a descent ohm range... you'd be stuck at either 6 (subs wired parellel, voice coils in series) or less then 1 ohm, .75 if my math was right (all of the sub wired parellel) and most amps can't handle that.
3: Same kinda problem, either 6 or even lower ohms.
Someone correct me if I am wrong, but that was the reason I bought SVC subs because at 4 ohms I could run a pair of SVCs at 2 ohms while DVCs left me with the option of 1 or 4 ohms... neither of which I liked.
Even a bigger problem with 6 ohm subs because then you have 6 ohms instead of 4....
Old Apr 24, 2001 | 03:42 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Well, since each coil is 6 ohms, you can wire them so each sub is 3 ohms. Therefore, in a single sub system, the amp would see a 3 ohm load. This is slightly less then 4 ohms, and just about any quality amp should handle a 3 ohm bridged load just fine. If 2 subs were wired in parallel, the amp would see a 1.5 ohm load, which is what i used to run with my JL 10W6s. If 3 subs were used, you would get a 1 ohm load which most comp type amps can handle.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 3/14/01)
There can be only one!!
[This message has been edited by Justins86bird (edited April 24, 2001).]
Old Apr 24, 2001 | 07:02 AM
dallasiroc's Avatar
In a single sub system coils wired in parallel it will be 3 ohm.
With coils wired in series will be 12 ohm.
With two subs coils and subs wired parallel will be @ 1.5 ohms.
With the coils wired in series and the parallel they will be @ 6 ohm
With three subs coils and speakers wired parallel will pull down 1 ohms.
With the coils wired in series and the subs wired in parallel it will be 4 ohm.
Old Apr 24, 2001 | 11:26 AM
FTC's Avatar
FTC
so if you get a three ohm load its safe to run this into an amp at 4 ohms or 2ohms?
Old Apr 24, 2001 | 11:44 AM
dallasiroc's Avatar
The ohm load on the Amp is determined by the Ohm the speakers are at.
So if the speaker is at 3 ohms that is what will be pulled from the amp.
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
lewandom
Oct 1, 2015 08:15 AM
ironbmt
Sep 27, 2015 06:00 AM
