Dash switch
Old Apr 26, 2001 | 05:24 PM
snoozeyaloose85's Avatar
Dash switch
What the heck is that switch with the music symbol on the dash of my 85TA. It just light's up but don't do anything is it a built in amp and if it is where is it located?
Old Apr 27, 2001 | 08:16 AM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
That's for the factory 4" subs in the rear sail panels. (IF you have them) Someone (like me) could've just added the switch. I've hooked mine up to my subwoofer AND the gain control works. With some more free time I'm going to write up a quick tech article SOMEday about it.
PS - From what I've read a TA didn't come w/ that stock, only GTAs, I could be mistaken though
Old Apr 27, 2001 | 08:37 AM
Well mine must have came with becuase it has all the wires for it. None are spliced or anything, it looks like a factory switch plus I don't think anyone messed with it cuase it's still the factory radio. The switch lights up when I turn on radio but don't do anything. I only have factory 6by 9's so should thers be some extra wires in there for some subs. Thanks.
Old Apr 27, 2001 | 09:34 AM
Car: '89 TA
Engine: LB9
Transmission: M5
Kinda dumb question, but have you changed your 6x9s OR PHYSICALLY checked that you actually have them behind the panels in the back seat area? That's where the factory sub enclosures go also.
the system included:
- the switch and wiring you have
- a 'premium' radio
- enclosures for the 4" subs and a pair of 4x6s in place of the 6x9s
- an amp to take the rear signal from the radio and output to the subs
If you have the 4x6/4" enclosures then you DO truely have the system from the factory (at least in MY book you do
If you have 6x9s back there i'd suspect some 'ghetto'-rigging
http://www.tcnj.edu/~esposit3
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Apr 27, 2001 | 10:22 AM
I went and checked and it looks like someone put 6 by 9's back there. They don't look like they fit good though someone broke some of the plastic around to fit them in. Any way where would this amp be located the wires go uder the dash somewhere. Also so I would have 6 speakers instead of fou? thanks
[This message has been edited by snoozeyaloose85 (edited April 27, 2001).]
Old Apr 27, 2001 | 02:18 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Sorry I forget the amp location ... places I >> THINK << its in are either right behind the radio or in the passenger's kick panel AREA, i know the ECM is there also.
Technically if you had the factory sub system.... you should have had 6 speakers: 4 4x6s and 2 4"s ... one pair of 4x6s would go up from like normal, and the other 4x6s would be paired w/ the 4"s in the 6x9 area.
As far as what powers what in that setup:
- the factory radio powers the 4 4x6s just like normal, 2 in back, 2 in front ...
- the amp uses the rear signal (splits it i BELIEVE) and amplifies it, sending the new signal (minus the treble) to the 4"s
PS - 100 posts!! Whoo Hoo!
[This message has been edited by Jim 86 Bird (edited April 27, 2001).]
The_Phoenix
Feb 4, 2016 07:10 AM
Stryker412
Sep 7, 2015 09:11 AM
luvofjah
Sep 3, 2015 07:08 PM
andy74
Sep 3, 2015 08:41 AM
Slush92RS
Sep 2, 2015 08:56 PM
