jim, your the expert on this
Old Apr 27, 2001 | 02:41 PM
termite85iroc's Avatar
Hey jim. I bought a alpine cva-1000 from a friend of mine for 500 dollars. It came with the monitor and brain and everything my only problem is there are alot of wires that go to nothing i can see. This is probably why the stereo wont turn on. Where do these wires go? there is one for the parking brake that I wonder if there is even a outlet for. Do you know of anywhere I canget some info on wiring htis up in my iroc?
Old Apr 28, 2001 | 07:52 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The parking brake wire is designed so that the monitor will only come out when the parking brake is on. I forget if this needs +12 volts or if it wants to be grounded. Other than that wire, it should only require the usual connections. I'll try to find out what that parking brake wire wants and I'll get back to you as soon as I find out.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
djmarch
Oct 2, 2015 10:41 PM
ASE doc
Sep 22, 2015 03:13 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
zimmstoy
Oct 9, 2001 01:04 PM
