keyless entry...
Old Apr 19, 2001 | 07:04 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
keyless entry...
Anyone put in a keyless entry system? I want to put one in but I heard that it was pretty complicated...
If you've done it give me some advice...
Thanks, Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job.
Old Apr 19, 2001 | 09:32 PM
Belker's Avatar
I installed a complete alarm system including keyless entry, trunk release, dual shock and dual radar sensors, and other goodies in one night. This was my first alarm install (having an alarm with built-in relays helped). Installing just a keyless entry system should be easy.
... Best Advice: Read the instructions. If you don't understand something then ask.
[This message has been edited by Belker (edited April 19, 2001).]
Old Apr 20, 2001 | 03:01 AM
MADOGIROC's Avatar
WHen i bought my Iroc it came with keyless entry, til I kinda broke it. Now it all came apart so yes it is possible.
Old Apr 22, 2001 | 02:33 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Alarm installations are time consuming, but not difficult. As long as you have the right tools you should have no problems.
I'm sure you know this but keyless entry requires power door locks.
Old Apr 23, 2001 | 08:48 AM
burntblues's Avatar
Car: 1989 Camaro RS
Yeah, I just heard that with all of the relays that you have to install that it gets complicated. What were the keyless entry systems you guys used with the built in relays?
Mike
Old Apr 23, 2001 | 11:58 AM
Pukka's Avatar
Its been awhile since I've worked on one, but relays aren't usually built in...they are either supplied with the alarm unit or you pay extra for them.
All you do is mount them in an appropriate spot, wire them into the alarm unit, and wire them into the switch you want energized.
Old Apr 23, 2001 | 02:06 PM
87 Firebird's Avatar
I put an Ungo start/lock combo into my bird. It was a bit tough for me, but just because It didn't have very much in the way of instructions. Basically said "this wire needs to be connected to X wire in the car" Nothing about location. It was a fairly flawless install, except for when I connected the "brains" and one of the chips went up in smoke. Turned out it was flawed from day 1. I'm getting a replacement unit sometime soon, i hope...
Old Apr 28, 2001 | 10:54 PM
Tigger84TA89BIRD's Avatar
I have a DEI python 1000 installed in my 89 bird with keyless entry, dual-stage shock sensors and a proximity sensor so I can leave my t-tops off and not worry about the car. I also am a manager for the local Car Toys and see these things installed every day. My suggestion is to HAVE IT PROFESSIONALLY INSTALLED.. there is way to much wiring to do and even with 9 years as a Radio Shack manager, I wasn't about to even try to figure it out.. just my .02 BTW... you will need two relays for the door triggers, and actuators if you don't already have power locks
[This message has been edited by Tigger84TA89BIRD (edited April 28, 2001).]
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
vinroc
Nov 28, 2001 08:34 AM
89 Iroc Z
Oct 7, 2001 12:59 AM
daniel91rs
Dec 21, 2000 10:23 PM
