sub sound
Old May 21, 2001 | 04:17 PM
87firebird's Avatar
sub sound
If I make A plate to put two mtx 6000 12" subs in that fits in the rear area will it sound as good as if I put it in a sealed box?
Is it safe to do this, or will it break anything?
Old May 21, 2001 | 04:21 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Nothing beats the sound of subs in enclosures....especially if the subs are made for them. A free air board still works quite well (I have one), takes up less space in the hatch area (great if you store T-tops, and doesn't look too gaudy.
As long as you anchor the board down you shouldn't have any problems
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old May 21, 2001 | 04:30 PM
KlayBuRn's Avatar
plates blow...you might as well just toss the subs in the back and you will get the same sound...
Old May 21, 2001 | 09:14 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Plates suck.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 21, 2001 | 10:53 PM
Fastcamaro87's Avatar
i had a plate with 2 10` in it, replaced it with 1 - 10" in a sealed box, and it kicks *** . way better than the plate,and i have more trunk space ,, however the plate does work ok for what it cost to make it..
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,TB coolant bypass ,polyurethane tranny and torque arm mounts, k&n oil filter,synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
