changing the radio
Old May 29, 2001 | 10:53 PM
92 z28's Avatar
changing the radio
hey, i goot a 92 camaro. does anyone know what type of wire harness i need to get to change the factory radio? like how many pins are needed? e-mail dozer80464@aol.com
Old May 30, 2001 | 09:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I don't know the part numbers for specific brands, but any car stereo store in your area will have them in stock. I prefer American International harnesses, but any brand will work. They usually cost about $15 and are color coded the same as all aftermarket wiring harnesses, so it's a simple matter of matching colors. I cut all wires to equal length. I prefer to use butt-connectors when I make my harnesses, then I tie-wrap the bundles of wires on both sides of the butt connectors to relieve any bending stress from them. Some people prefer to solder, which is a very good method, except that in the tight confines of GM dashes, they have a tendancy to crack when bent. Wire-twists are decent but I never reccomend them because they could always come apart. Hand twisting the wire should never be done. Take your time and do it outside of the car on a work bench with quality crimpers, and if you don't do it all the time, use a multimeter to do a continuity check on each wire before you install it. Once you're sure it's working fine, it's a simple matter of plugging into the stock wiring, then plugging it into the back of the radio.
Don't forget that your car is going to need an antenna adapter too.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 31, 2001 | 12:53 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
I got a harness tha was colered coded to EIA or EJA spec. It cost $9 as I bought it with the Alpine D852 HU.
Only problem is the HU doesn't have enough juice though the power antenna lead (blue) to raise it. I'm gonna do the relay thingy (stereo shop through one in after I went back) and see what happens.
86 T/A 5.0
93 Civic 1.6L
13.5 @ 100 mph
Old May 31, 2001 | 01:16 AM
Tigger84TA89BIRD's Avatar
For a 1992, the merta part # is 70-1858 or schoche part # is gm02. you will also need an adapter to fir the dash unlesas the new stero is 1.5 DIN, which is the size of the factory deck. metra part # 99-4500 or schoche part #gm1500b
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Chuck84TA
Aug 27, 2015 11:14 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
