help with amp
Old Jun 3, 2001 | 11:02 PM
jkueker's Avatar
help with amp
i just hooked up my 1000 watt amp but didn't use the battery to hook it up. i went through the fuse box because there was a part of it that always was hot. well, now my amp goes into protection mode. is it caused by not going from the battery directly? if it is, how should i get from the battery to the amp in the trunk of my car the easiest, all i need to do is get to the fuse box actually. i have an 89 trans am gta. i need to know how to wire it through the firewall of the car. if anybody can help i'd appreciate it.
jkueker
Old Jun 3, 2001 | 11:14 PM
transam350's Avatar
I also have a 89 GTA and your amp is cutting off because of it not getting the volts it needs i ran my power wire thourgh a hole that was already in the firewall just below the wiper motor.
hope this helps
89 T/A GTA 350 TPI free mods and all stock
15.21 @ 89.7
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
