engine block ground?
Old Jun 2, 2001 | 12:14 AM
Belker's Avatar
Does anyone know where the ground strap that grounds the engine block to the chassis is located on a 91 RS 3.1? Where does it bolt to the block? Where does it bolt to the chassis?
Old Jun 2, 2001 | 08:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Maybe ask the guys in Motor Swap. They would know. As far as I know, the engine uses the motor mounts as a ground. I looked for a ground strap in the 3.1L in my Haynes repair manual, but don't see anything about it.
Old Jun 2, 2001 | 11:54 PM
Belker's Avatar
I recently upgraded the power wire from my alternator to my battery and the ground wire from my battery to the chassis. Wow ... what a difference! My battery is charging better, voltage is higher, system is better. Now I just need to upgrade the engine ground strap and the job will be done. Any help would be appreciated.
Old Jun 3, 2001 | 05:25 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The engine can't use motor mounts as a ground. The motor mounts are designed to totally isolate the motor from the chassis through rubber. The V8 cars run a strap from the fire wall to the passenger side head, and I'd assume your car does the same.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 3, 2001 | 09:43 PM
AJ_92RS's Avatar
My bad.
Old Jun 4, 2001 | 11:12 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
On my car the engine ground is on the passanger side near the distrutor and it grounds to the firewall... What kind of wire did you use for the alt to the distrubtion block??? i want to do this also i was thinking 8 or 4 guage wire possibly 0 guage. but im afraid the connectrs might not fit into the distrubtion block.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
