Kicker Class D Amps
Old Jun 4, 2001 | 10:30 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Kicker Class D Amps
WHat's the deal with these amps and radio reception?
I have a DX700, and when it is powered up, I can't get squat on the radio. I realized the connection to that amp when it was out being repaired. I had great radio reception until I put it back in, then I might as well have disconnected the antenna.
Do I just need to run the power wire far away from the antenna lead?
TIA
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads look good, (just sitting there doing nothing!LOL))
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Jun 5, 2001 | 05:10 PM
Polecat's Avatar
That's about the only connection I would think. Try moving it and see what happens. That's weird.
Old Jun 5, 2001 | 08:05 PM
JP84Z430HP's Avatar
Car: 84 Z28
Yeah, I though it was weird also, but I wanted to throw it out there and see if anyone else had heard of this. I knew that the topic would grab your attention, Polecat, and knowing that you are a part of the Kicker organization, maybe you know about it. Well, it'll probably be a couple weeks before I can get time to do, but I'll post again when I do try it out!
Oh yeah, I also wanted to mention that I have 2 ZR 120's in there that didn't cause an issue when the 700 was out.
Thanks.
[This message has been edited by JP84Z430HP (edited June 05, 2001).]
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
