Help!!! Need help building sub box
Old Jun 14, 2001 | 09:40 PM
87CamaroChris's Avatar
Car: 1987 Camaro
Engine: 305 LG4 Carb. (no ECM)
Transmission: TH700-R4
More specifically I need good and detailed plans (with measurements) on how to build a sub box that will fit in the back of my Camaro and will hold two 10" subs. Any help would be appreciated.
1987 Camaro Sport Coupe
305ci 4bbl (LG4)
3.23 Gears
THM 700-R4 Automatic Transmission
All Stock
Old Jun 14, 2001 | 09:50 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
All the measurements you need are just 1 tape measure away. That's how most of us found the dimensions. As long as you take your time, and account for the thickness of your wood, it won't be too hard.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 14, 2001 | 10:48 PM
Car: 1987 Camaro
Alright, I guess I'll do the measurements the hard way, but how bout some good plans (what I really need is to see how they are designed).
305ci 4bbl (LG4)
3.23 Gears
All Stock
Old Jun 15, 2001 | 09:47 PM
Ragin'87's Avatar
it really depends on what you want it to look like, and what you're plans are.. that and how good you are with wood. I'll post pics of my box and the measurements when I finish it and install it(should be around thursday.).. it's almost exaclty 1 cu. ft., for 1 10", fits all the way down in my trunk, leaves enough space to put my t-tops in the back, and enough room on the sides for a six-pack and some tools.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 76k miles.
GTAman
Jul 3, 2024 07:29 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
64goatman
Sep 9, 2015 01:09 PM
Amillionoh7
Sep 5, 2015 11:44 PM
