A square tube box?...
Old Jun 16, 2001 | 01:06 PM
Camaro_hunter_d's Avatar
well I have another posr asking about good sub boxes...and well I just though of this...
I have 2 12 Rockfordfosgate RFZ1812's and was thinking about building a square tube box to sit in the well... Have them facing each other and have ported behind the subs... well heres some idea of size...
Roughly 38 inches long 12 inch square ends. So 38 by 12 by 12. Anyway have between 4-5 inches of the top's center removed. To act like a "mega" port and have a small 2-3 inch port behind the magnets...I was thinking of having the subs mounted around 4-5 inches inside the box so there would be 28 inches of free space between them.
Would this work? has it been tried and failed?...some opinions please...
Old Jun 16, 2001 | 05:46 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Box shape makes no difference. As long as the volume is correct, and the port size/length is correct, you'll be fine. Just make sure that the volume and port size are right though. With a ported box, you need to be pretty accurate with these or it will sound bad and cause damage to your speakers.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
gta892000
Aug 11, 2019 11:16 AM
BLK87Z
Sep 18, 2015 11:29 PM
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
