6X9 boxes
Old Jun 20, 2001 | 05:56 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
6X9 boxes
Since I've got my interior out, is the "box" that GM made for our 6X9's any good? I was thinking of making a new box myself, probably will be too lazy, but I'd like opinions anyway.
Old Jun 20, 2001 | 06:20 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
GM didn't make a box. There's a little plastic wrap covered insulation back there which is mainly just designed to damp resonance so that the exterior panels don't vibrate. Other than reducing vibrations, it's useless.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 20, 2001 | 10:50 PM
Hummer's Avatar
Car: 1986 Z28
Yeah, that's the 'box' I was talking about. I would think that any kind of insulation would help around there, since the resonance would rattle the body panel. Is it worth boxing, or does that insulation work as well as anything I can build for such a small area?
Old Jun 21, 2001 | 07:07 AM
Jim85IROC's Avatar
It really depends on your specific application. Most 6x9s are well enough damped to work fine in an infinite-baffle style enclosure. Putting them in a small box tends to hurt lower bass output and make them thick or boomy. If you built a large enough enclosure, it would help, but it would be a very complex enclosure to fit down in there. I'd say pull that fabric enclosure out, stick a little dynamat to the panels in there, then put that enclosure back in and install your speakers. That'll be pretty easy and will sound pretty good for most applications.
The IROC Homepage
Old Jun 21, 2001 | 07:19 AM
9177's Avatar
I've been wondering about that stuff back there also. would it be better just to get rid of it altogether or would that hurt the sound?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
