Quick question-please answer quick:)
Old Jun 22, 2001 | 09:34 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Will I get feedback if I run my deck's power wire close to the ground? I think yes...brain freeze!
Old Jun 22, 2001 | 10:55 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
No you shouldn't have any problem. Just make sure your wires are good so that you don't create an electrical short.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jun 23, 2001 | 12:12 AM
myposcamaro's Avatar
ill be blunt..
i haveeeeee nooooo ****kinnnngg clue!
kev
Old Jun 23, 2001 | 12:32 AM
Camaro_hunter_d's Avatar
No you will not get any feedback. I have my power wires for the 2 amps, cross over, EQ, and head unit along with the grounds running right beside each other...
Current 3rds...92 3.1 coupe and a 91 T top 305 Past camaro's 74Z28, 2 75 camaro's bretilina and a 76 z28. Past rides HA HA too many to count, at least 20..LOL Kills to date a new one today a 98-up Grand prix..I know They usually eat us alive but I hit third hard and chirped he flashed his lights and backed off!!! a 3.1 firebird 2 stop lights in a row.
95 Grand Am
Serveral Honda's
a friends 91 Rustang LX(I know its a 4 but he keeps trin')
Planned mods:
Soon coming 3 inch exhaust, 1.6 rockers, High flow 'Verter, and Ignition system. Along with a complete turbo 4.3 swap planned later this year(hoping to get into the 10's..)
Current mods:
Set of Iroc sway bars front and rear..amazing differance, Air box bottom completely removed allowing my K&N to act like an open element filter.
Lower profile tires, 195/55/15 front 205/55/15 rear handles better.
And a 160 deg thermo for a V8(and yes it works just fine)
Sterio Sony CD head unit and 9 band EQ, Boston acutics 4x6 dash, Alpine 3 way 6x9 sail, California sounds active crossover, Kroiiler 600 watt amp powering the 'pines and Bostons, 600 watt Jensen powering 2 Rockord Fosgate RFZ1812 subs. And all this cost less then $575...
Old Jun 23, 2001 | 09:09 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You won't have a problem. Every power wire in your car runs directly beside a ground. The chassis of your car is grounded, so in effect, every wire is next to ground. Plus if you look at an amp, the power and ground wires are almost always next to each other.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
