If you guys want measurements to a custom box
I guess I'll take out my box and copy the measurements for you. Its a box that fits the back of the trunk, and makes a 90 degree angle with the hatch glass. Holds two 12" subs.
If nobody wants the measurements then I wont take em. But hey sometimes I need to occupy myself :P
From: First one out of liberty city, burn it to the ground
I want measurements!! TIA
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
1989 Firebird
Coming for my v6:
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Cool, thanks man!
What kind of subs did you build the box to hold? And what is the internal CF of the box?
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
Fast355
Dec 2, 2016 06:33 PM
