Pluging a clarion help needed
Old Feb 9, 2002 | 09:58 PM
CaMaRo_Berlinetta's Avatar
I have a clarion radio and was wondering about a wire the yellow one witch is the one that i plug to the batterie
Does this wire plug on direcly one the battery
(the wire is small )
never plug a radio but the reste is easy
just wondering how u guys plug that wire
Old Feb 9, 2002 | 11:40 PM
Belker's Avatar
The Yellow wire should be connected to a constant (even when the car is off) 12V source. This wire is for the HU memory.
(edit: The yellow wire doesn't have to be connected directly to the battery. There should be a factory wire behind the HU (or at the fuse box) that is constantly hot.)
The other power wires are: Red - ignition (only hot when key is turned on) and Orange - illumination (only hot when headlights are turned on).
Old Feb 11, 2002 | 12:01 AM
boricua482's Avatar
get a volt meter and check which one is on w/o starting the car or w/o anything on, etc.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
