Amp cuts out...why????
Old Jul 9, 2001 | 04:10 PM
custman87T/A's Avatar
I have a Profile 440XL I took out of my old car and transferred into this one. I mounted it in the rear glove box. After about 20min. of driving the amp just cuts out and stops putting out power. If I turn the volume down and wait for a minute it comes right back and works for approx 5 min. then happens again. Is there anything I can do about this???? What can be causing this???
Old Jul 9, 2001 | 04:48 PM
will0325's Avatar
to me it sounds like ur amp is clipping, the glove box gets no ait circulation, i haven't had any experience w/profile amps, so i can't say anything about how ggod their heat sinks are, but try moving the amp to like uner your seat and see if it is better. i think the amp is just heating up too much and clipping.
Old Jul 9, 2001 | 05:24 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I could be wrong but I think the term "clipping" has to do with inducing too much gain on the input signal. I think (hope) what Will is trying to say is that your amp is reaching it's thermal shut-off point. It has a circuit that will turn itself off if it starts getting too hot. If you have to use a Profile amp and you have to mount it in that compartment you might try getting a small electric fan for it.
Old Jul 9, 2001 | 05:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Clipping is when the output voltage of the transistor exceeds the maximum rail voltage, so the signal is incapable of being any larger. But that's a different problem than what you have. Yours is going into protection mode because it's overheating. This is one of many unfortunate consequences to using a "budget" amp. To eliminate the problem, you need to drive a higher impedance, or keep the amp cooler by better ventilation.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 9, 2001 | 06:56 PM
Thanks...I was thinking along the same lines of a heat problem. I gutted the glove box hoping that would give it adequate ventilation. What kind of fan can I use to cool the amp or what amp do you recommend that puts out 400-500 watts/4chan. that will fit in that location. I would like to keep it there for security reasons but if I have to move it I guess I will.
Old Jul 9, 2001 | 09:42 PM
Jim85IROC's Avatar
Just a fan isn't going to help. It's in a concealed area, so once you heat up that air, all a fan is going to do is move hot air around. The only thing that may work is to duct air from the vents in the plastic cover, through a fan and directly onto the amp.
The IROC Homepage
Old Jul 9, 2001 | 10:22 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
or get a hatch shade and leave the amps on the rear deck. no one will smash out your windows if they don't know what's in there.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
raymondandretti
Sep 27, 2015 06:43 PM
