Amp overheating
Old Jul 13, 2001 | 05:15 PM
Buck Mustard's Avatar
Amp overheating
I have a Kenwood KAC-626 amp wired to my old Bazooka sub. I think the amp was 70x2. For the speaker hookups, it has some writing that says "bridge" by connecting left side + with right side -. I then ran these wires to the + and - posts on the old Bazooka speaker.
It was working, but after driving for awhile it cuts out. Then it will come on again eventually. After I got home today, I checked the amps. My RF 400a4 that runs the 4 other speakers was just warm. The Kenwood was insanely hot - it burned me!
So I assume it is overheating. I don't know much about wiring this stuff up or ohms or anything. Do I have it wired incorrectly?
The amp sits on the hump behind the rear seats and should get as much airflow as possible. The RF is right next to it and (like I said), it was fine.
'88 GTA w/ t-tops
355 TPI, TPIS airfoil, Edelbrock headers,
Flowmaster exhaust, cold air induction,
MSD 6AL ignition, ADS chip, 1.6 rockers on intake,
BMR STB, Spohn SFCs
Stereo:
Panasonic CQ-DFX700U
Infinity 4x6, Alpine 6x9
Rockford-Fosgate Punch 400a4
80 watt Bazooka sub
Old Jul 13, 2001 | 08:44 PM
Jza's Avatar
Jza
The 626 is a 50x2, and make sure you flipped the switch for that setup. Is the bazooka 2 ohms? The 626 won't run a 2 ohm load while bridged or it'll do exactly what you describe.
Old Jul 13, 2001 | 08:54 PM
I flipped the switch on the amp from stereo to mono. How do I know if the Bazooka speaker is 2 ohms? Assuming it is, should I just run the amp non-bridged from the left side... or what?
Old Jul 14, 2001 | 02:35 AM
Jza's Avatar
Jza
I guess so. It'll handle 2 ohms in stereo, just not bridged. You'd have to look on the bazooka somewhere to find out it's impedance (i never mess with the things, never seen one, don't really want to).
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
