85 Camaro Dash Removal
Old Feb 12, 2002 | 10:15 AM
Gail's Avatar
Car: '85 Camaro/08 Hond./99 Mack Truck C
Engine: 5.0/4 cyl. in-line/Cat. Diesel
Transmission: A/OD,/A/OD,/Automatic,no O/D...
Axle/Gears: 2/2/and 4 OD, OD, auto.
I bought my Camaro in 1985. In 1988 I tried to remove the dash cover to replace the stock speakers. I did not remove the dash because it would not budge. What is the secret. I do not want to break it and at this point I would almost just give up trying. I want to replace the radio, again, and hopefully all the speakers this time around. Thanks.
Old Feb 12, 2002 | 10:20 AM
jobryan26's Avatar
To remove the Dash Pad there are if I remember right 4 screws inside the defroster duct area and then ones along the upper front across the length of the dash(like above the Gauges and etc)
Old Feb 12, 2002 | 02:25 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Yeah, get the screws on the defroster area, and the screws under the front part of it. If they all are free, with a good but not hard yank it should come out. I pryed mine out and put a crack right above the steering wheel, i did it the stupid way, i never asked how to take it out, i assumed. Don't make any decisions if u aren't sure what ur doing.
Old Feb 12, 2002 | 06:32 PM
Belker's Avatar
With all the screws removed, mine comes out REAL EASY.
No yanking required.
Old Feb 15, 2002 | 10:09 AM
Gail's Avatar
Thanks for all your tips. I will try again in a day or two. I think I will also try the two screws under the vents just above the radio/ heat controls. I can not remember if I took them out before. Again, thanks. I will let you all know how it goes, and if more help is needed.
Old Feb 15, 2002 | 10:43 AM
Gail's Avatar
Thanks, for the tips. I will try again in a day or so. There are the screws that are in the heat vents just above the radio/heater controls that I might not have tried to remove before. If there is a screw, it will be removed. I will hopefully get this done very easily. Thanks again. I will let you know if more help is required. I will let you know if I am successful too.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
