Remote Faceplate
Old Feb 12, 2002 | 09:04 PM
BlueAlice91bird's Avatar
Remote Faceplate
Ok, so I was reading on here a while back on mounting your faceplate for your HU remotely and thought this would be awsome. I hate the glare I get on mine from the sunlight. N E way, I did some searches for the post I was reading and can't find it anywhere. So I guess I'll just ask. How do you do this? Some specifics would be appreciated. thanks in advance.
Old Feb 13, 2002 | 10:25 AM
jobryan26's Avatar
Good with a Soldering Gun? Use a cable with alot of small wires in it kind of like a telephone cord. Make the faceplate wired by soldering the connectors from the faceplate to the headunit. You may need a few wires to do it as there's quite a few connectors there.
Old Feb 15, 2002 | 01:21 AM
So just what kinda wire, and would it be possible to make a sort of extension cord, with the male and female ports on either end, rather than solder. That way it would still be detachable.
Old Feb 15, 2002 | 02:59 AM
jobryan26's Avatar
Using some type of connectors I don't think would work. I would say that's one of the reasons you don't see this done that often. Or atleast when I've thought about doing it I decided not too because I didn't want to ruin the ability of putting my HU back to normal. I can't think of any type of cable with alot of wires in it other than a Telephone cord. It has 4 wires in it and it's overall diameter is quite small so that's what I'd try. Maybe someone else could give some suggestions as to a cable that would work better.
Old Feb 15, 2002 | 03:41 AM
Ozymaendaiaez's Avatar
Delete
Old Feb 15, 2002 | 07:06 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
you can get all sorts of different ribbon cables from radio shack. If you really needed to still make it detachable, you'd have to do a hatchet-job on the deck to take the contact patch off and relocate that part too. Of course, to keep the faceplate secure, you'd basically need to remove the whole front of the radio and put it behind the faceplate.
Or... get a 2nd radio to chop up.
Old Feb 15, 2002 | 11:12 AM
jobryan26's Avatar
I thought about CAT5 Cable but thought it might be too thick never played with it before. And the IDE cable also but didn't think it would be long enough.
Old Feb 17, 2002 | 12:45 AM
Jza's Avatar
Jza
You can buy that kind of computer ribbon wire in bulk..
Old Feb 18, 2002 | 07:39 PM
krzy 92 formula's Avatar
Ok now i really wouldn't recomend using cat 5 line or telephone wire. I've done this mod to mine and a few other show cars.
I work with one of my buddies who owns elliot electronics in okc.
He does work for toyz with nouize and many others. I will post pics of kine when it is done but i fried my faceplate so it will be a little while. Oh and by the way pc ribbon cable is the best it'll be reall hard strip it back but try to keep the bare wire to less then a mm. One other thing to think about is the length of the wire.
Some units i've done couldn't take more then 3 feet and some that took over 20 and no problems. It is difficult but worth while in the end and looks bad. Turns alot of heads.
Old Feb 18, 2002 | 08:07 PM
What's wrong with CAT5?
And have you ever worked with the Panasonics? If so how far would those go?
Just curious, thanks for the info
Old Feb 19, 2002 | 02:51 PM
If you would like to you can use cat 5. Just in my experience ribbon cable is alot cheaper and easier to work with. Also a flat thin ribbon cable will lay smooth inbetween the two peice case on your deck and easier to get to fit coming out of the faceplate. Where the round larger cat 5 would require a nice sized hole.
I have done one panasonic but it was a older one but it could only got about 3 feet and then it started showing weird characters and acting funky.
Good luck
P.S. a magnifing glass and a very small soldering tip help out alot.
Old Feb 27, 2002 | 02:54 PM
project=T/A's Avatar
how about 10 core thermostat wire(like the kind used on house furnaces)its only about a 1/4 inch round and has 10 solid copper wires in it,,wouldnt the solid wires make soldering easier?
Old Feb 28, 2002 | 05:56 AM
sbd4de3's Avatar
Anybody got any pics of a remote face plated stereo system?
Would like to see them if you do!
Steve
Old Feb 28, 2002 | 09:45 PM
Not yet, but soon............................. I hope.
1992Z28!
Nov 19, 2015 07:33 AM
tglennon11
Sep 23, 2015 05:30 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
anesthes
Aug 24, 2015 08:18 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
