Bose system wiring
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Bose system wiring
Ok I have a 1992 Camaro with a AM/FM cessette radio in it, I want to use a 1993 Bose CD player from a 4th Gen. Camaro, will that work as far as wiring????? Would I have to make any changes or is all GM stuff standard as far as plugs.
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
The wiring is the same, as far as the speaker outputs, and the power and ground. The Bose deck does NOT have an internal amplifier whereas the standard AM/FM Delco decks do. This is because ALL Delco Bose units have individual amps on each speaker. ALso, the Bose deck sends power (same wire to the powere antenna) to a relay which turns on the speakers, since each one is individually powered. The standard stereo has only the amp in the deck. You could do it, but you'll need a 4 channel amp or 2 2 channel amps in order for it to work right.
[This message has been edited by tommygun (edited July 22, 2001).]
Street Lethal
Apr 30, 2019 12:14 PM
db057
Aug 11, 2015 10:11 PM
