Witch ohm to run Kicker L7?
Old Jul 25, 2001 | 03:15 AM
Funnyinaz?'s Avatar
Ok i am about to order 2 Kicker 12in Square Solo Barics. They will be run by a Rockford Punch 800.2. Ok now what ohm subs should i get 2 or 4. And how should i run them with this amp?
Old Jul 25, 2001 | 01:50 PM
Polecat's Avatar
Cool....
The L7's come in DVC 2 ohma dn 4 ohm. It depends on what load you want to put the amp under, and what it's most stable power output is.
With two DVC woofers, here is the amp load.
DVC 2 ohm woofers can be done on an amp load of 2 ohm or 8 ohm.
DVC 4 ohm woofers can be done on an amp load
of 1 ohm and 4 ohm.
If that amp is stable to a 1 ohm load, get DVC 4 ohm woofers.
Old Jul 25, 2001 | 06:52 PM
Funnyinaz?'s Avatar
Ok so how do i know what my amp will be stable to run at. Anyone have experience with this amp? Thanks.
Old Jul 25, 2001 | 07:00 PM
Polecat's Avatar
Here are the specs:
200 W X 2 @ 4 Ohms RMS @ 1% THD
400 W X 2 @ 2 Ohms RMS @ 1% THD
800 W X 1 @ 4 Ohms Bridged RMS
Old Jul 25, 2001 | 07:08 PM
Funnyinaz?'s Avatar
So i should get the 4 ohm woofer and run them bridged at 800 watts at 1 ohm. Also what exacty is bridged. Sorry about all the questions this is my first car/install thanks. Bobby
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
