CD Player will not play CDs
Old Aug 1, 2001 | 05:05 PM
RallySport1992's Avatar
I got a Jensen CD515K CD player about 7 months ago and installed it myself. It was working perfect up until now, then all of the sudden it starts to say Error-4, which was a disc focus error or something like that. So I press the reset button like it says in the manual and it doesn't help it at all. The radio and everything works fine. I called the manufacturer and they said it may be due to low voltage and to check the ground wire. Well I checked all my wiring and it looks all good to me. Should I take the ground wire out of the wire harness and put it directly onto the chassis itself? Or is there someplace I can check to see if the ground wire has been shaken off or something like that? It doesn't even sound like the CD spins at all. Its really frustrating since I spent a ton of money on my system.... and i hate the radio...
Old Aug 1, 2001 | 05:16 PM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Sorry for your troubles with Jensen equipment, RS...
Uhh, Jim85IROC... you want to take this one?
Frankie Rider, 2
The GTA Source Page
'88 GTA Red Hatchback - 5.7L/A4
'88 GTA Black Notchback - 5.7L/A4
'88 GTA Gunmetal Hatchback - 5.0L/A4
Old Aug 1, 2001 | 06:26 PM
KlayBuRn's Avatar
well my friend, Jensen spelled backwards is junkyard...
and how the hell did you spend a ton of money on Jensen ****? heh, Jensen is like food club, your Jensen is shot, your changer lasted as along as my 500 watt...er 5 watt amp
Old Aug 1, 2001 | 07:32 PM
I spent $220 on the CD player, I don't have a CD changer. Then i bought an amp and 2 subs (not jensen products), thats how it got expensive. If you can't help me out, then why say anything at all? I just thought maybe someone with a similar problem might know what to do, rather than attempt to make jokes at my problem
Old Aug 2, 2001 | 02:42 AM
Neo's Avatar
Neo
Are they normal cds or CD-RWs, CD-Rs? Some decks are picky with those.
Old Aug 2, 2001 | 09:54 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Try grounding it to the chassis. Make sure you are using an audio CD, not a CD-R as mentioned in the last post.
If that doesn't fix it, then I suggest you get it repaired.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Aug 2, 2001 | 07:19 PM
Alright, I got some great news- I found my recepit!!! Thank God for that. All I can say is if you buy anything from Jensen keep that receipt in a lockbox and do not buy a Jensen head unit just because it fits flush in the console, Pioneer makes a much better "din and a half" GM head unit, but thanks for your posts!
Old Aug 3, 2001 | 02:30 PM
KlayBuRn's Avatar
sorry meant player not changer
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
