Wiring tweets
Old Feb 17, 2002 | 11:24 PM
5.0L1992RS's Avatar
Wiring tweets
I little while back I posted a question about hooking up some tweeters in my car. Someone said that If I wire them parallel with the 4x6's it should work fine. Just to make sure I didn't mess anything up, I wanted to make sure this would work. I know that getting some kicks instead of 4x6's would work better or wiring an amp to them would work better, but, I have the 4x6's and tweets so I am going to use them.
Also, parallel wiring is: negative on tweet to negative on 4x6 to negative on deck and positive on tweet to positive on 4x6 to pos on deck. Is this right?
Old Feb 18, 2002 | 04:07 AM
nagga's Avatar
yes thats right, but DO NOT wire them to your 4x6s without using a crossover, you will have no tweets left after while, tweeters are meant to play in the kilohertz range, not 40-200 hertz
so u need a crossover that will play from like 500-22,000 hertz
then you will be fine, cause if you blow those up, it definatly hertz the pocket, tweets are like 100 a set lol
also how loud is that 80 series muffler??
Old Feb 18, 2002 | 10:11 AM
5.0L1992RS's Avatar
Yea, my tweets come with a built in crossover.
The 80 Series muffler sounds great over the stock. It isn't super loud becuase it is a TBI. My friend has the same muffler on his 85 TPI and is alot louder than mine.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
