Specific Volume?
Old Aug 8, 2001 | 10:19 PM
Lostsol's Avatar
Specific Volume?
Howdy, this post is in reference to an Infinity Perfect 12" that I bought a while back. Included with the speaker was a sheet from the factory suggesting very specific dimensions and volumes for speaker boxes to use. The Ported box that I prefer I didn't take the time to figure out how to make one fit, and never made one before anyway so I bought a Sealed box. The suggested Volume is 1 cf and the box I have is 1.2cf. Question is this, Is this an acceptable difference in volume or will it greatly affect the performance? Also, I had planned on spraying some Roadkill along the seams inside the box before I installed the woofer. Any thoughts, suggestions or anything would be much appreciated. Take care now
Old Aug 8, 2001 | 11:47 PM
Mike92RS's Avatar
If you want to reduce volume, just put .2 ft^3 worth of wood or something in the box.
- Mike
[This message has been edited by Mike92RS (edited August 08, 2001).]
Old Aug 8, 2001 | 11:55 PM
matthew's Avatar
actually your box is just right. remember that the whole subwoofer inside the box is displacing some volume so that makes up for the .2 cu ft. of extra volume. My perfects are in a .88 ft^3 box and they sound fine.
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
Old Aug 9, 2001 | 12:14 AM
Lostsol's Avatar
I have been wondering if the manufacturer took the volume displaced by the rear of the sub into their consideration when making their dimension and volume suggestions. I don't imagine it'll make a whole lot of difference either way though but I do like to know. As for the wood suggestion, I have been playing with the idea of putting a boarrd in the bottom, or a brace of some kind; but once again would like more feedback. Thanks guys...
Old Aug 9, 2001 | 12:48 AM
Mike92RS's Avatar
Oh yeah good call I forgot all about driver displacement. My 12" takes up .11 ft^3, so if your's is similar in size, you should be within 10% of the volume and it should sound alright.
- Mike
Old Aug 9, 2001 | 07:35 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Sealed enclosures are not as volume-critical as ported and bandpass. You can vary the size a bit and get predictable results. 10 or 15% variations are barely noticable. Anyway, I usually like an enclosure bigger than what is reccomended. Most manufacturers reccomend an enclosure that will give a decent sound and a decent bump. I prefer a smoother, more accurate response even if it means a slight loss in sensitivity, so I build my boxes 15-20% larger than most manufacturer's specifications.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 9, 2001 | 08:09 AM
Lostsol's Avatar
Well, thanks to all of you for your input. It's greatly appreciated. Take care now
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
MrPackstin
Oct 25, 2017 08:09 PM
Vintageracer
Sep 24, 2017 12:34 PM
Gordonr1973
Sep 29, 2015 11:59 AM
