Pioneer Amp
Old Aug 9, 2001 | 11:45 PM
Shawn84SC's Avatar
Pioneer Amp
I just bought a Pioneer GM-X802 that did not work. After fixing the bad solder connections, it worked fine for over an hour. I picked the amp up(while it was playing) and it started kicking on and off very quickly and blew the fuses. After replacing the fuses the amp barely plays, all the levels have to be turned down all the way and the deck is turned down to about 1 or 2 or the amp will start kicking on and off again. The heatsink also got very hot very fast. Is this blown transistors? If so, how much is a full set? Thanks..
BTW: This is the older GM-X802. 100x2/4ohm, 300x1/4ohm
[This message has been edited by Shawn84SC (edited August 09, 2001).]
Old Aug 10, 2001 | 06:57 PM
Shawn84SC's Avatar
ttt
Old Aug 10, 2001 | 07:40 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It sounds like they could be blown. If it's getting hot, chances are the output is shorted either somewhere in the wiring, or in the FETS themselves. In either case, I'm sure it did permanent damage to the FETS. Whether it's the output fets or the power fets is another story, but if you look at them you should be able to clearly see the burned ones. Just get the model number off the fets, and I'm sure any electronics supply store can get them for a couple bucks each.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
