Do you need an amp for this?
Old Aug 12, 2001 | 06:50 PM
89Firebird Formula350's Avatar
I have 2 questions: Can i put a component system in the front and the back? Do you need an amp for a component system to work good?
Old Aug 13, 2001 | 09:43 PM
Chevy83Z28's Avatar
if you're gonna be running components, i'd definitely run them off an amp. the head unit's power just isnt enough and nowhere near clean enough. you'll also need the crossovers (should be supplied with the components though.) good luck.
Old Aug 14, 2001 | 12:41 AM
TrueBlue91RS's Avatar
Yes, component systems are possible to install in the front and in the back. However, while doing the back is relatively easy (remove factory 6x9 plates, use as a stencil, fashion new plates for component speakers and crossovers), the front is a bit more difficult due to space restraints. Depending on what size component you want to install, it may be hard to squeeze it into the area once occupied by your dash speakers. And of course you have to find room for the crossover as well. Not to deter you, just keep in mind that a bit of modification may be necessary.
Old Aug 14, 2001 | 11:45 AM
ArnoldBraker's Avatar
Just build some kickpanels. It's really not that hard.
Old Aug 14, 2001 | 11:59 AM
DJSexay's Avatar
Buying kickpanels is even easier
mike
custom 3rd gen kickpanels at http://www.lachernet.com/kickpanels
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
