2 12" subs in cargo cover lid?
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Can i put 2 12" subs in the cargo cover without a vibration problem. Or any problem? I figure foam tape or something like it around the edge of it, but any other advice?
Thanks in advance.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
Painter @ Chevy dealer
GM junkie
Thanks in advance.
Kenney
GM junkie
Inside its gonna sound kick *** , but you will get some raddles outside. Depends how much bass you will be putting out and if you really dont want rattles then dynomat the rear and it will help alot.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
doing that is just like using a plate. Plates suck. The bass is sloppy and will not get loud. A single 10" sub in a tube will sound much better and will be as loud/louder than 2 12s in a plate.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
