Undoing dash bolts in 4x6 installation trouble..
Old Aug 25, 2001 | 04:33 PM
SexyCamaro's Avatar
I'm trying to install some new boston acoustics 4x6s, but I cant seem to find a way to undo the 4 bolts closest to the windshield, anyone have any suggestions?
Old Aug 25, 2001 | 04:45 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Assuming you've already tried a 7mm small socket and rachet, how about a small 7mm wrench, or small adjustable wrench? It'd be tedious, but then again it's only 4 bolts
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
Member of FBS
AOL IM Name: JimmyTime5
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Aug 25, 2001 | 04:47 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Sorry, just thought of something and the options bar for "edit" doesn't seem to be appearing near my post...
If you're possibly talking about getting the dash pad off, you just need a long phillips screwdriver
Old Aug 25, 2001 | 04:59 PM
SexyCamaro's Avatar
The bolts that fasten the dashpad are hexagonal, so a screwdriver wouldent work. The reason I'm having trouble doing these is because I cant seem to fit any tool in that vent area, my ratchet needs an adaptor which is too long, and pretty much any tool with a handle wont work because of the angle of the bolt and the windshield.. so the only thing I can think of is trying to loose them with some pliers and try to finger them out
Old Aug 26, 2001 | 03:07 AM
irocbod's Avatar
if your talking about the four in front of the defroster vent then they should be phillips, MAKE SURE NOT to let them drop down into the vent it's a bitch to get them out. You can get new ones but the old ones just rattle. Anyway you should just have to use a magnetic driver exstention, took me thirty secs with a makita and an extention. If it's not a phillips try the same thing but with different bits.
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
The_Phoenix
Feb 4, 2016 07:10 AM
red90IROCls1
Aug 25, 2015 06:56 AM
