wood cutting question for all you box builders
Old Aug 24, 2001 | 05:23 PM
Ziggy89Formula's Avatar
OK. I've made all of my cuts for my box and cut out my holes for speakers and terminal cups. I test fitted some peices, and so far everything is going as planned and looks good.
Here's the problem- I can't make correct angle cuts on the edges. I have it designed to sit flush with the slope of the rear hatch and need to cut the edges at the proper angle. The way I thought I could do that did not work at all. I've got a radial arm, table saw, circular saw, and dremel all at my disposal. Can somebody give me a quick carpentry lesson?
Thanks for the help!!!!!!
89' Firebird Formula
Black/grey cloth
305 TPI/5 speed/3.45 rear
dual cats/PW,PL/T-tops
K&N, SLP TB booster,
SLP exhaust, Jet chip
Old Aug 24, 2001 | 11:13 PM
Nevermind. I figured it out.
Black/grey cloth
Old Aug 24, 2001 | 11:26 PM
Mike92RS's Avatar
So what'd you do?
- Mike
Old Aug 25, 2001 | 02:05 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You apparently figured it out, but I'll provide this info for the others that may want it:
Make life much, much easier and just use a 45 degree angle instead of trying to match the angle of the car. Any circular saw or skil saw will let you cut at a 45, and you don't have to worry about getting the compliment of the angle at the other side because it'll be 45 too.
I suggest cutting the flat angled piece, and saving the sides for last. Once the front and back of the box is done, you can just hold a piece of wood in place and trace it to the other pieces and Voila! A perfect match with absolutely no measuring or calculations.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 27, 2001 | 08:44 AM
<font face="Verdana, Arial" size="2">Originally posted by Mike92RS:
So what'd you do?
- Mike
</font>
I probably did it the most difficult way possible, but it worked. I lined up the angled board with the sides (that are already cut to the proper angle on the front side). Then I drew a line on the edge of the angled board to match the sides for a flat top surface. Then I took a T-square and drew a line all the way down the length of the board. I then took the wood to the table saw, lined it up properly so that the blade cut where the line is (holding it at an angle as I pass it through the saw), and just had very steady hands. I sanded any small imperfections with the belt sander. It's a very haphazard way to do it, but everything fit together nice and tight.
There's ways to do it with a miter box but I don't have one of them. In the future, I think I'll take Jim's advice!
Black/grey cloth
Terrell351
Jun 13, 2021 01:13 PM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
reiderz iroc
Aug 13, 2015 04:57 PM
mx127
Aug 10, 2015 08:13 AM
