Heya, Engine noise, How Do i Get Wired???
Old Aug 30, 2001 | 11:21 PM
FiReBReTHa's Avatar
ok, well, i installed my power wire, along fender, inside fender, and drilled a hole underneath antenna grommet....
wheres this noise coming from?
Oh, and other than that, IT KICKS *** !!!!
i need to hurry up and get cash for kickpods..
when the car is off theres no static...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Aug 31, 2001 | 07:12 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You made no mention of what kind of noise it is, or any description about the system ground. We'll be needing that info to help.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 31, 2001 | 07:54 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Where is your power wired connected? If the noise stops when the engine is off, if could be caused by the alternator. You can buy filter designed to eliminate this.
Also make sure your system has a good ground.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Aug 31, 2001 | 09:46 AM
FiReBReTHa's Avatar
good ground....
ive yet to find the permenant spot for it, where should i ground? but thats not the problem
the sound is static...
after i made this post i went outside, and turned the key.... no noise...
tell me bout this filter.......
Old Aug 31, 2001 | 05:42 PM
FiReBReTHa's Avatar
hmm. what else could it be though if its not alternator?
Later, im going to disney world
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
