general help
Old Feb 25, 2002 | 01:27 PM
speedfreaker's Avatar
general help
im pretty sure this has been dragen ito the ground but i can find a simular topic anywayz can i bolt my amp down on the rear deck will it hit the gas tank or be ok if not what else can i do thanks
Old Feb 28, 2002 | 11:42 PM
custm1992's Avatar
DO NOT DRILL INTO THE REAR DECK!!!!! you will rupture your gas tank!!!! instead, pull up the carpet, put a piece of medium density fiberboard 3/4 of an inch thick under where you want to mount the amps, and screw into the wood, hint : cut the wood in one big piece from left panel all the way to right panel so that it doesn't slide around. make sure to use small enough screws so you don't screw into the gas tank
Old Mar 5, 2002 | 11:57 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
heavy duty VELCRO* (prickly side)
Old Mar 6, 2002 | 06:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow; popular topic lately, eh?
Why not build a full-out amp rack up there? Take up the whole deck with some wood, surround it with plexiglass, put the distribution block up there, put a "push" fan aiming in one side, and a "pull" fan pulling air out of the other...
[edit] Oops- oh, and to bolt it down, use steel straps (two on each side, or maybe even plate steel) to go "under" the plastic panels on each side, and bolt the straps to the side supports that are back there. That way you won't hit any gas tanks!
(Plexiglass enclosure) on top of (amps) next to (distribution block) on top of (board) on top of (steel brackets going to the sides of the car) on top of (original carpet).
Old Mar 6, 2002 | 08:52 PM
custm1992's Avatar
don't use velcro. It makes the amp too east to steal
:hail:
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
