Need opinions
Old Sep 14, 2001 | 05:29 PM
ArnoldBraker's Avatar
Need opinions
I have a line on an Alpine amp, 3527. It's a 4x25 watts RMS. The gye wants $95. Good price? Oh, it's a what does 4/3/2 mean? I was thinking about bridging all 4 channels together to run my Boston components in my kicks. I'll leave the rear 6x9's on the HU and get a separte amp for my sub(which I don't have yet). What do you think? Any opinions are welcome. ~Arnold
Old Sep 14, 2001 | 11:05 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
4x3x2 and should also be x1, means that thats how many components "4 channels total" can be driven from the amp.
Sounds like a fair price for a quality name 4 channel amp. IMO its much better to run all your speakers, kicks&sails through the amp, I dont know of any head unit that puts out 25w per channel rms and most 6x9's need 25rms as a min.
SSC
Old Sep 15, 2001 | 01:36 PM
I had always heard that if you give sails too much power it will screw your soundstage up. That's why I was going to leave them on the HU. I guess I'll have to do some more research:-)
Old Sep 15, 2001 | 09:16 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
SSC, almost all 4 channel amps CANNOT be run into one channel. The 4/3/2 means.....
(4) 4 channels @ 25 watts or
(3) 2 channels @ 25 watts plus the other 2 bridged into one and you'd get about 70-80 watts
(2) 2 bridged channels at 70-80 watts each.
So he would us in in the bridged mood and run approx. 75 watts each to the Bostons.
$90 sounds fair depending on how old the amp is. If it is one of the old black ones, $40-50 is fair price.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 16, 2001 | 11:46 PM
<font face="Verdana, Arial" size="2">Originally posted by Mista:
</font>
I am confused at how you get 70-80 watts out of two bridged 25 watt channels. Shouldn't it be more like 40 to 50 watts? Sorry, kinda new at all this BTW, it is a black amp, (not a v12) So I'll probably offer about $50 ~Arnold
Old Sep 19, 2001 | 07:05 AM
Mista's Avatar
Car: 1986 Trans Am
2 channels at 25watts into 4 ohms = 50 watts mono into 8 ohms. In a cheater amp this would yeild a true 100 watts into 4 ohm mono.
I have 3 old 3522 amps rated 30x2 at 4 ohms or 80x1 into 4 ohm mono. It is the old "black" chassis with Duo Beta circuitry. I had one burn a chip on the board and the tech called me back after repairs.....
at 12.5V it was pushing 50 x2 into 4 ohms and not even close to clipping.
THAT is a amp! at 14.4V it was in the 65x2 into 4 ohms from a amp rated at 30x2.
I've been saving it and it will see use in the front stage of my TA.
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 20, 2001 | 07:30 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I agree with SSC. I don't know what kind of 6x9s you are running, but I have an MTX amp pushing 70 watts RMS per channel to a pair of Eclispse 6x9s. Trust me, they sound way better with an amp than without.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
