AMP Question!
Old Mar 1, 2002 | 07:31 PM
britered86transam's Avatar
AMP Question!
hey guyz i had to take my amp out of my car so i could get the body repaired, i jsut got the car back today, it looks great! but my problem is that whenever i attach the battery cable to the amp it blows the fuse! does anyone have any ideas on what might be casueing this??? thanks
Old Mar 1, 2002 | 09:24 PM
5.0L1992RS's Avatar
sounds like you are touching the power wire to a metalic object that is grounded. I always seem to do that at least once when hooking up an amp.
Try unhooking the power wire from the battery and then hooking it up to the amp and then hook back up the battery. If it still does it, I have no idea what it is.
Old Mar 1, 2002 | 10:40 PM
custm1992's Avatar
your power wire is grounding out. before you hook ANYTHING up, trace a path along the wire until you find where it's touching metal. If you absolutely, positively find no grounding, it's probobly your amp
:hail:
Old Mar 1, 2002 | 10:51 PM
ok you guyz are saying the my power wire is "grounding" im not sure what that means...does it mean that somewhere on my main power cable there is a slice in the protective coating and the wires inside are touching metal somewhere?
Old Mar 1, 2002 | 10:53 PM
custm1992's Avatar
exactly
Old Mar 2, 2002 | 06:39 PM
TrueBlue91RS's Avatar
Here's another quick thought on this:
What part of your car got repaired/painted?
If it was around the area that you had your amp ground wire connected to the body/chasis, then the body shop might have a) removed the amp ground and not re-attached it or b) removed the ground connection, painted over it, and then replaced it again meaning that your ground cable is no longer touchiing the metal surface directly.
Of course, this is only useful info if they were working in the area of your amp ground. But it would be worth checking. Good luck!
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
