Amp for 2 10" HE2's w/DVC
Old Oct 18, 2001 | 01:32 AM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
I will be running all four voice coils in mono.. thats all four in parallel with each other @ 1 ohm...
I have my eye on the bd1000.1 from RF, but dont know how it will like the 1 ohm. I know sony advertises their 1000 watt amps run their best at 1 ohm, Im just curious if rf does to, but doesnt advertise it.
Will it shut itself off?
What other amps do you suggest?
No License, No Hope.
FILTERCHARGED BABY
Old Oct 18, 2001 | 07:10 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Sony amps will run at 1 ohm, for somewhere between 5 and 8 minutes.
If you insist on running such a low impedance, check the Rockford Power series amps or the higher end Kicker amps (I forget what they call that line right now).
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 18, 2001 | 01:28 PM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Well what do you suggest I do 2, 4 ohms?
FILTERCHARGED BABY
Old Oct 18, 2001 | 02:11 PM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Bawls:
</font>
doing a series/parallel configuration will give you a 4 ohm load which will give you a lot more amp choices if you're looking to save money. If you want 1 ohm bridged, you need to shell out the money for an amp that can handle it.
The IROC Homepage
Old Oct 18, 2001 | 03:10 PM
FrostsZ28's Avatar
cant u wire those 2-HE2's so that they running in 2ohms and still run all 4 voice coils, they have a wire wizard on RF's website. what doe they require rms per voice coil?
If its not a camaro or corvette then what is it really?
Old Oct 19, 2001 | 03:13 AM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Here's what im going to do.
http://crushed.org/caraudio.php
FILTERCHARGED BABY
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
