someone pleae help with rear speakers.
Old Oct 19, 2001 | 01:27 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
I need a good material to make an enclosure to fit 6x9's in the rear panels. For some reason my car did not come with factory rear speakers because there is nothing to hold them in. What would i use to make an enclosure. could someoen help me or should i jsut run 4x6's in the front and just use my sub box in the back and don't worry about the rear speakers? someone help.
86Z28, 350 gm motor, Borg Warner 5 speed, hurst shifter, 3.73's, Edelbrock heads and carb, Edelbrock headers and cat back 3" all the way, 2 1/2" cowl induction hood, and K&N air filter.
Old Oct 19, 2001 | 01:42 PM
Undrtkr25's Avatar
There is no 6x9 hole behind the piece of fabric along side the rear seats? If not then you could buy the 6x9 boxes from Crutchfield.
'89 Chevy Camaro
305 TBI
COMPLETELY stock
Old Oct 19, 2001 | 02:28 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
There is no way you can fit a crutchfield 6X9 box in there. Goto the junkyard and pick up a set of speaker mounts. They can be from a camaro or firebird it doesn't matter. If you can, find one that has the fiber backing in good shape. That helps the sound a lot.
Happy hunting.
Old Oct 19, 2001 | 02:57 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Personally, I would not worry about back speakers. Rear speakers are ment for fill. Your front stage produces almost all of your soundstage. This is why your front speakers are so important. Buy a set of DJ's kickpanels and put some good components in there. Or if you don't have the funds (like me ) get good 4x6's.
Hope this helps,
Matt
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
-Profesionally Built Turbo-350 with Hurst shifter & B&M shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat. & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
Old Oct 19, 2001 | 05:36 PM
Undrtkr25's Avatar
I meant put the boxes behind the seats not in the factory local.Crutchfield sells waterproof foam baffles that can be used behind the speakers if you can find out how to mount em in the factory locals
'89 Chevy Camaro
305 TBI
COMPLETELY stock
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
