Wiring HU from scratch, where does the Yellow Go?
Old Oct 24, 2001 | 11:46 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The Red wire goes to the fuse box, the black is ground, the blue is remote, and the yellow goes where exactly? Whoever had the car before me was an electrical yuppie and acted like he was playing with christmas lights. So I've completely rewiring my stereo as I put my new stuff in. But I just don't know what the yellow, specifically connects to.
Old Oct 25, 2001 | 02:58 AM
Omar's Avatar
I believe yellow is illumination. I could be wrong. Check it with a test light.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Oct 25, 2001 | 07:42 AM
GndPrx's Avatar
Red - Switched Power
YELLOW - CONSTANT POWER (MEMORY)
Black - Ground
Blue - Remote/Antenna
These 4 are standard across all aftermarket decks.
Orange is generally illumination or dimmer
Most manufacturers have moved to standard color for speaker wires as well...
White / White/Black - Left Front
Gray / Gray/Black - Right Front
Purple / Purple/Black - Right Rear
Green / Green/Black - Left Rear
Carl
CarAudio Resources
CarAudio Resources Forums are now ONLINE!
Old Oct 25, 2001 | 11:31 AM
I'm aware the yellow is memory.
Where does the yellow wire from the deck hook up to? And am I wrong saying the red goes to the fuse box?
Old Oct 25, 2001 | 01:42 PM
GndPrx's Avatar
Red goes to any power source that is on when the car is on. The factory fuse location for the radio is a switched power source if I'm not mistaken. The yellow goes to any constand source of power (i.e. directly to the battery) or any other source that is on weather the key is on or off.
I would strongly recomend using a test light or volt meter to find these sources. Also do not tap into other circuits (i.e. lighting, etc...) that may already be at their proper fuse rating. Try to use the original radio circuit if you can.
Carl
CarAudio Resources
Reddeath210
Oct 6, 2015 08:20 AM
Glowsock
Aug 26, 2015 12:28 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
ZsTransAm
Aug 11, 2015 07:30 PM
