Can you guess that wire?
Old Oct 25, 2001 | 07:56 PM
Cla$$ic85's Avatar
Well, I had my console apart, and upon putting it together a wire came out of my Pioneer Deck... cuz it no longer will turn on. The wire is a pretty thick gauge wire. It looks like a RCA. It has a red circumference on the end. There is a white one that plugs into an adapter then to the back of the deck. But I have no idea where this "red" one goes. Anybody know?
Old Oct 25, 2001 | 08:10 PM
XxInFaxX's Avatar
the way you're describing it sounds like it is the antenna...but they are usually black...i dunno about the red part
Old Oct 25, 2001 | 08:23 PM
Cla$$ic85's Avatar
The wire is black, but the end is like a RCA jack. When you look at it around the edge, surrounding the "male part" it is red. The the wire is black. I was thinking it was the atenna too... but wouldn't the dech still turn on?
Old Oct 25, 2001 | 08:40 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Yes it is the antenna. No the deck will not turn on if it is dissconnected or if it is not properly grounded. This should fix your problem. Usually antennas plug straight in the deck and not in a harness, you shouldent miss it.
Hope this helps,
Matt
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
-Profesionally Built Turbo-350 with Hurst shifter & B&M shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat. & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
Old Oct 25, 2001 | 08:42 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
It is possible that one of the power wires or the ground wire came loose. If the wire you are talking about is an RCA, there should be another one with either a black or a white end running right beside it. If it is an RCA, the problem with the deck not turning on is probably unrelated. Check all of your connections.
[This message has been edited by Eric's85TA (edited October 25, 2001).]
Old Oct 26, 2001 | 01:46 PM
Cla$$ic85's Avatar
Fixed the problem, thanks alot.
midge54
Dec 27, 2019 04:14 PM
Cleotiz
Jan 6, 2018 08:56 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
