check out my setup...question about CAP.
Old Oct 19, 2001 | 06:19 PM
j166a99's Avatar
here is my setup fellas, my ? is, is my cap set up right? i've been running it like this for a while now and no problems. i basically have it connected to the distribution blocks just like the amps. one for power and the other for ground.
my system slams, but there is a bit of dimming. nothing totally noticeable, but i am a perfectionist of some sort. ill take pics soon.
'86WS7
Ram Air...
*EiyseWhite*
Old Oct 19, 2001 | 09:52 PM
OldOneEye's Avatar
Car: 1997 Nissan 200SX SE-R
Engine: 2.0 Liter SR20DE
Transmission: 5 Speed
That's fine. Try to get the cap as close as you can to the amps (power wire length wise anyway). The closer the cap is to the amp the better.
Juan
Old Oct 20, 2001 | 08:37 AM
KlayBuRn's Avatar
the best thing to do, would be whatever you bass amp is, i would run the cap inline on the power wire coming from the block to the amp, like a foot or so away from it, that would be the best...
Old Oct 20, 2001 | 04:08 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
From your diagram, it looks like your attempting to share the cap with 2 amps. You really should wire it inline with the sub amp. If you cap is more then 12" away, its basically useless due to the power cable's internal resistance. Try to mount it within a few inches of the amp. Also, you do not want a fuse between the cap and amp.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
Old Oct 22, 2001 | 12:11 AM
AudioDEO's Avatar
Car: 89 Formula 350
Engine: a Big one
Transmission: I dont keep them long.
well that should work but remember some light bulbs will change in intensity with just a few tenths of a volt difference and unlsee your going to install about 50 of those caps your not going to keep it from dimming completly...
its like they say once you get to a certain level to get any higher you have to spend 1000 times the effort and money.....
Old Oct 22, 2001 | 08:26 PM
Belker's Avatar
Correct me if I'm wrong .... I interpret the word "inline" to mean wiring in series .... shouldn't a CAP be wired in parallel to the amps (like shown in j166a99's diagram)?
Old Oct 26, 2001 | 09:22 PM
j166a99's Avatar
what you basically see there is the way my setup looks like (exactly), if you were looking at it from the rear with the hatch up. (im picking up a digicam real soon, so ill post pics then...)
you guys brought up a good point which was what i missed. normally a setup would consist of a cap running inline right before sub amps (i'm using 1 amp/sub) so i figured that it would be the same if i placed it in the distribution block, instead of 'inline' (also, it looks nicer that way).
my question, is that right, or should really run inline (before the dis. block)???
thanks fellas...
'86WS7
Ram Air...
*EiyseWhite*
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Numbah-1
Sep 12, 2015 08:57 PM
