HOW DO I GET RID OF THESES SUB/SPEAKERS
Old Oct 26, 2001 | 08:50 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
Hi guys, I have the system with the gain, im i have a little speaker and kinda like a sub, i want to put some nice 6X9's how do i get rid of this subwoofer type box
1986 TPI 305 TRANS AM
Old Oct 26, 2001 | 09:33 PM
CD MaroMan 91's Avatar
Don't get 6x9's... put a good 5¼" or 6½" component set... i think ur seeing is a tweeter and a midrange which is a component set. Trust me a good component set will sound better than a 6x9
'91 Camaro RS 3.1L V6
4th Gen Seats, Sony Xplod CD Player, DJ Sexay's Kicks Panels on the way, Polk Audio 6½" Comp Set, 2 RF Punch 12's, RF Punch Amp 100.2, Coustic 360W Amp, Kelly Charger Front Tires. Soon to come, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
http://www.geocities.com/adidaspredator21/index.html
[This message has been edited by CD MaroMan 91 (edited October 26, 2001).]
Old Oct 27, 2001 | 10:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's just a few 7mm screws holding it in. You'll probably have to losen the plastic panel to get it out though.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 27, 2001 | 10:53 AM
CODY BEHNKE's Avatar
What you have is the factory sub system, a panel with a 4x6 and a 5 1/4 "sub" this was a factory upgrade in 85-88 T/A's. If you really want to take them out just remove them and put 6x9 mounting plates out of a 6x9 equiped 3rd gen in.
Old Oct 30, 2001 | 08:53 PM
TOM305T/A's Avatar
Does anyone know the rms on the factory sub and the 4 x 6. i want to change the system over to a 6x9 and a seperate sub. or do i just upgrade whats there
Old Nov 4, 2001 | 07:41 PM
FstBrd6point3's Avatar
U need to loosen the bolts on the perimeter of the box, and then unplug the sub. . .in order to get the box out tho, I needed to take the top speaker off, because I couldn't find the harness, it was burried. once the box is loose you need to work it a little bit to get it to slip right out. Be carefull not to strip the screws along the endge, or else the box won't seat right again and it rattles like hell, I learned the hard way and had to do mine twice over.
sailtexas186548
Jan 19, 2016 12:21 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
Street Lethal
Aug 12, 2015 11:33 AM
