My soundstage sucks
Old Nov 2, 2001 | 08:57 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My soundstage sucks
I got done putting some Boston 4x6 plate speakers into my GTA, and so far everything I've listened to is coming from one spot in the middle of the dash. I have no soundstage at all. It's like the two speakers are being fed a mono signal. I'm using the Alpine that worked just fine in my IROC a couple days ago, so I'm looking elsewhere. I'm going to try reversing the polarity of 1 speaker, but I suspect that if they were out of phase that my soundstage would be very diffuse, and not pinpointed at the center of the dash.
Anybody else have any suggestions?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 2, 2001 | 09:15 AM
9177's Avatar
Man not very often you ask a question. Anyway i have an older alpine amp and on mine there is a switch for mono, 1+2ch, and stereo. i don't know if yours has this feature but its the only one i can think of.
Old Nov 2, 2001 | 10:31 AM
FiReBReTHa's Avatar
ug, sorry ta hear bout that bud, hmm... i missed your post on why you have 4x6's again.... foot space or something?
sorry ta hear bout that, but your saying that when they were in your other ride, they had no probs but now switched they do?
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Nov 2, 2001 | 07:11 PM
DJSexay's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jim85IROC:
Now that I need tunes in the GTA and I don't have the time and the patience to build another set of kicks right now,
</font>
I have the cure for that.
mike
custom 3rd gen kickpanels at
http://www.djsexay.com
Old Nov 2, 2001 | 10:26 PM
Jim85IROC's Avatar
Well, I switched the polarity on one of the speakers, and it's now like it should be. The image is fuzzy and unfocused, but at least I've got a wide soundstage.
In other news, I installed a nice Denon deck into my Sport Coupe. It's got a red display. Oh my. I love red. It would match the IROC perfectly. Now I'm caught in a dilemma. I really would like a bit of a nicer deck for the IROC, but I finally found a red deck to match my dash lights. Decisions decisions...
The IROC Homepage
Old Nov 3, 2001 | 03:30 AM
jobryan26's Avatar
I did the samething in my car Idunno why they put those wires azzbackwards like that. Glad you figured it out.
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
[This message has been edited by jobryan26 (edited November 03, 2001).]
Old Nov 3, 2001 | 09:22 AM
DJSexay's Avatar
just get a deck you like, then make it red. That's what I did to my 7949.
mike
Old Nov 3, 2001 | 11:10 AM
DTGuitar's Avatar
JIM!!!! I emailed you! Did you get it? Regarding buying a box.
Dan
Daniel Galley
'88 IROC - SLP Exhaust
2 12" JL W3's.
Old Nov 3, 2001 | 04:27 PM
Jim85IROC's Avatar
DJ, how did you change the colors? I thought All of the new decks have the multi-color, sealed display? I didn't think it was like the old units that you could just change the backlight color on?
DT, I got it and responded, but my email has been FUBAR lately. I responded the last time you sent me that email, but I'm guessing that you never got it. Let me know if you don't get this one.
The IROC Homepage
Old Nov 3, 2001 | 05:07 PM
DJSexay's Avatar
my alpine had little green rubber covers over the lights. I just replaced those with red ones I got from PartsExpress.com . The actual lcd display retains it's multi colors, but all the buttons now light up red.
Mike
Old Nov 3, 2001 | 08:23 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
Jim, when you say polarity you mean switching the wires from negative to positive right? This has an effect huh? I have a terrible soundstage in my car. crappy sub, top of the line rockford 6x9's and 4x6's. i have my amp powering the 6x9's and the sub, and my deck pushing the 4x6's. for some reason, when i fade it all the way to the front, i still can barely hear the 4x6's. when i fade it to the middle i can't hardly hear them over the blasting 6x9's. I hate my 4x6's..... any suggestions for now till i get kicks?
1987 LG4 Camaro z28
Modifications- Flowmaster 80 series, KN airfilter, high flow cat, 180* stat, edelbrock performer intake manifold, msd blaster coil, ascd big block hood, panasonic cd player, rockford everything else.
Old Nov 3, 2001 | 10:55 PM
JannaMan's Avatar
Was just reading the thread here... one person's balance problem could be the deck driving the dash 4X6's... Had that problem before, but the new upgrade included Infinity Kappa plates (60W rating - one of the higher ratings out there) driven by my Sony 4x75 amp, with the with the cutoff at 300hz. Problem solved...
Now for the imaging problem from the dash, I'm currently installing Polk MOMO tweeters that will be mounted in "pods" I am building that will suspend vertically downward from the dash - the LH one near the light switch cluster, and the RH one just to the right of the center A/C duct. It won't exactly be "symmetrical", but the distance to my ears will be very close (who cares about the passenger heheheh). Since the upper frequencies are VERY directional, and the tweeters DO swivel, this should prove to be quite interesting...
Old Nov 4, 2001 | 08:29 PM
Jim85IROC's Avatar
Twinkies, I switched the polarity of just 1 speaker. This changes their phase relative to each other, which can cause some major differences in sound.
Janna, I can't imagine having anywhere near equal path lengths in the position you're talking about. That seems like the path length diffence would be even worse than the dash. I can reach the light switch without even extending my arm. With my arm fully extended, I'm like 4 feet from the other side. That's a HUGE difference in path length.
The IROC Homepage
Old Nov 5, 2001 | 10:24 AM
JannaMan's Avatar
</font>
Hmmmmm.... perhaps I was unclear in my description... sorry 'bout that! Actually,
the signal path is about 26 inches on the left side, and about 29 inches on the right. The LH being just above the light switch, and the RH just to the right of the CENTER UPPER A/C ducts.
Hopefully that made more sense this time!
Old Nov 5, 2001 | 12:43 PM
Jim85IROC's Avatar
Oh. Kinda makes for a narrow soundstage, but whatever floats your boat I guess.
The IROC Homepage
Pac J
May 17, 2020 10:44 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
tyeo098
Nov 30, 2015 06:27 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
