hawk project update
hawk project update
just for you guys keeping tabs on my project, I aborted my first plans, and am well underway on plan B. Take a look and let me know what you think.
http://www.djsexay.com/hawk
I'll have more up by early next week.
mike
- link fixed now -
custom 3rd gen kickpanels at
[This message has been edited by DJSexay (edited November 08, 2001).]
mike
- link fixed now -
From: First one out of liberty city, burn it to the ground
link doesnt work.
1972 Chevy Chevelle "Malibu"
Hooker Headers, Flowmaster 40 series mufflers, accel 8.8 wires,Edelbrock performer intake Edelbrock Carb, Msd Blaster 2 Coil, Torque Thrust "D" wheels
Click here for my Malibu information
In Memory of #3 Dale Earnhardt
It's not working for me either
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
See my Ride:
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Fix that link or be prepared to face my wrath!
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
-Justin-
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Link worked fine for me. Car's looking good!
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
oooh, goodie goodie....If I can get the bird done in time I can go up against Mike in Daytona...
Of course I'll be missing about half of my equipment still and I'm currently only getting started on my 5th revision of how I want the car to be built :\
Lookin good so far.
Are you still keeping the sub in the rear quarter?
What did you end up using to texture the dash kit?
AND last but not least...
You mixed epoxy resin with polyester bondo????? Are you sure that will hold up?
Carl
CarAudio Resources
CarAudio Resources Forums are now ONLINE!
Lookin good so far.
Carl
CarAudio Resources
the dash piece is textured with SEM texture spray, it matches the dash texture pretty close.
The sub is going in the passenger side quarter panel, with the amps where they are, there is no room for a sub in the driver side.
The filling of the trim ring is as follows:
1st layer is epoxy resin with fiberglass cloth. Then, I filled in about 1/4" of bondo to fill up just shy of the top. The, more epoxy, mixed with glass spheres, fills in the top to bond to the plastic. I just used bondo in the middle to get a quick build up, however, I am thinking of remaking the piece our of 100% epoxy, just cutting out the bondo center and starting over, just to ensure there is no splitting, but it has held up so far.
Heh, I'm still missing EQ's, front stage, and various install parts (new battery, neons, etc ...). A lot of work ahead. Must sell kickpanels
you doing pro street 0-600 ?
mike
!!you doing pro street 0-600 ?
mike
Yes on the pro street 1-600
Well, if you have that piece already made and if you are worried about the seperation, just make a mold off of that piece and redo it out of all epoxy...if you make the mold right you will retain the texture, the texture will be more "permenant" and not wear down since it's in the glass and you'll never have to worry about the compatability problem
(hrmm, DJSexay's custom 4th gen dash kit...$50 each)
otherwise just add talc to your epoxy mix to make your own epoxy filler rather than bondo...
Let's see, I'm still missing my processor (IDOne not released yet), 8's, horns, 5's and sub...
I've got enough to make a temporary system from my last show car and just replace pieces later in the season, but don't know if I want to go through that hassle as opposed to doing it correctly the first time.
Need to sell off these EQT's and PPI xover to get the money for the IDOne.
Carl
CarAudio Resources
(hrmm, DJSexay's custom 4th gen dash kit...$50 each)otherwise just add talc to your epoxy mix to make your own epoxy filler rather than bondo...
Carl
CarAudio Resources
yeah, I did mix some fine glass powder to the epoxy to make it thicker, but not enough that is was real paste like. I'm at least redoing the center of the trim ring, cause when I made the opening with my router, my template bent a little and made the hole bigger. I't's not a 1 din, but actually will flush around the flip down face of the head unit.
Good luck with finishing you project up as well. I look forward to meeting and competing with you in Daytona.
mike
mike
new pics updated ! It's in phase 2.
mike
mike
Lookin really good Mike.
Carl
CarAudio Resources
Carl
CarAudio Resources
