factory gm cd player
Old Nov 16, 2001 | 12:44 PM
silentneko's Avatar
my best friend is getting a system for his 2000 blazer, can I use his cd player and front dash speakers in my 87 trans am
neko
'87 trans am
car in the making
Old Nov 17, 2001 | 03:56 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
You can use the speakers if they are a 4x6, if not you will have to do a little modifing to make them fit in the dash of your car. The stereo will not work because the connectors are different on back of the stereo, or unless you want to trace down the wires for power, speakers and anything else there might be for the stereo.(you will also need to cut off the harness connector as a pigtail to splice in the wires to you car) Your friend might not want to do that. Hope I helped you out.
1989 iroc-z 350 TPI, auto trans, leather int. t-tops, edelbrock headers and cat back system, SLP cam, crane double roller chain, 4 wheel disc, and aftermarket hood. Iroc-z's forever, Ford Mustangs NEVER
Old Nov 17, 2001 | 11:44 PM
Chris Luongo's Avatar
You can buy an adapter to plug his newer radio into your older car at a GM dealer; I'm not sure of the cost.
Or you can go to Best Buy and purchase two plugs... one fits your car, one fits your friend's radio...... splice them together and you're all set. Cost is $16 for each piece.
Or if you like to go the junkyard, cut the harness out of any newer GM car. Then you only need the other $16 harness.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Linson
Oct 1, 2015 09:50 PM
