Problem - Amps not working!
Old Nov 26, 2001 | 11:42 PM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
Ok, this happens everytime I disconnect the negative power lead to work on something, and then plug it back in. My receiver still works because I can see the music playing (mine has a spectrum analyzer thing), so I know the CD is playing. However, my speakers (wired through the amps) don't turn on. Sometimes this fixes itself, but it is annoying as hell. Any ideas as to why it is doing this? Thanks
Eric
Old Nov 27, 2001 | 10:50 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I could be when you disconnect the ground it resets your HU and you HU has a menu that turns on your amps. Does it? How many times has this happened? What did you do the other times to get it working if it did?
-Matt
Old Nov 27, 2001 | 03:18 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Removing the negative wire is not good. All you are doing is removing the ground, which can be substituted with another ground path that can include body parts.
You should remove the positive wire when working on electrical equipment. If you have your memory lead from the H/U wired to a separate point you will not have do any reprogramming.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
Old Nov 27, 2001 | 04:56 PM
nagga's Avatar
actually, u should always remove the ground from the battery when attempting any electrical work, thats the safest way to do it
Old Nov 27, 2001 | 09:38 PM
deadtrend1's Avatar
IF you remove the postive from the amp, take out the fuse under the hood. I neglected this onetime and i had a nice tiny circle burned on the top of the amp. It still worked though .. =D
1991 Firebird (GT40)
-LO3 305 TBI
-5 speed
-Open Element Air Filter
-Edelbrock Tower Strut Brace
-Kenwood Excelon Headunit w/ 10 Disc Changer
-Alpine MRP-F256 Amp
-Polk EX 4x6's, DX 6x9's, and EX Tweeters
-Kicker ZR240 amp (bridged)
-Dual JL W0 12" Subs
My page with pics and stuff, and car stereo help.
http://members.aol.com/deadtrend1/index.html
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
Fronzizzle
Aug 9, 2015 01:15 PM
