Stereo System Question, Please Help
Old Mar 14, 2002 | 11:15 PM
StarOfLife's Avatar
I have 2 Sony Xplod 12's being pushed by a kenwood 1000w Amp. I had it hooked directly into the battery but after I added my interior neons, it seemed as though i was pulling to much power from the batter. (i.e. my battery would be dead) Should I add a spetate battery solely for the purpose of my neons and my system, and if so, how do i go about installing it and keeping the batery charged? Thanx
Old Mar 14, 2002 | 11:18 PM
87transam5.7tpi's Avatar
what kinda amp alt do you have? and are you sure its charging correctly?
Old Mar 15, 2002 | 02:31 AM
coalyard's Avatar
You should check that your amp and neon system are not remaining on when the car is off. If they are turning off, have your alternator/voltage regulator tested, and your battery too. If all of that is OK, then you have a low level drain on the battery. To find it, remove your negative battery terminal, and hook a digital VOM between your negative battery post and negative cable with the car off. If the meter shows anything more than a few milliamps draw, start pulling fuses one at a time until you find the circuit that is causing the drain.
Adding a battery does nothing more than put an extra load on your alternator, so I usually suggest upgrading to a heavy duty alternator instead. If you listen to your system with the car off a lot, I would also step up to a gel cell battery.
69 Six Pack
Oct 5, 2015 07:51 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
redmaroz
Aug 16, 2015 11:40 PM
