Who sprays undercoating in their sub boxes?
Old Dec 12, 2001 | 10:42 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I've heard of people spraying that black rubber undercoating in their sub boxes. Does it just seal it up better, or is there a dampening effect as well? Also, does the uneven surface it creates have negative effects on the sound waves?
Old Dec 12, 2001 | 11:26 PM
jobryan26's Avatar
I think I remember Jim saying something about doing something like that. Maybe he could shed some light on it.
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Old Dec 13, 2001 | 07:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I spray mine. Does it matter? Probably not. I do it for 2 reasons. The first is just one more level of protection incase I missed a spot when I siliconed it. If there are any pinholes in the silicone, or if there's a small gap, the undercoating will fill it in. Secondly, it adds a minimal amount of damping to the box. The rough surface will not have any negative effects on the sound, and if anything, the irregular surface will help to minimize reflections of high frequency harmonics.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 13, 2001 | 04:32 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Thanks, if it can't hurt anything, I might just do it before putting the box in my car.
Old Dec 13, 2001 | 06:05 PM
OldOneEye's Avatar
Car: 1997 Nissan 200SX SE-R
Engine: 2.0 Liter SR20DE
Transmission: 5 Speed
If you do spray the stuff, let it dry a bit. Just to make sure that you don't have nasty stuff floating around inside your box that might cause problems with the surrounds on the subwoofers. I for one would just use fiberglass resin. An MDF box isn't completely sealed (if you don't believe me, take a shop back and put two pieces of MDF together.. you can pick the bottom piece up right through the top piece).
Juan
Coming soon, CES report 2002 at Sound Domain www.sounddomain.com
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Oct 7, 2015 10:15 AM
loud91rs
Oct 5, 2015 10:05 PM
