equalizer help
Old Mar 26, 2002 | 03:57 PM
Jessica's Avatar
equalizer help
I bought an 87 iroc-and there was already a box and amp in it. I can't figure out how to work the equalizerr for it-and i cant find any instruction manuals or anything for it. Its a cleartone QE-2200-if that helps.
Also-i have a JVC KS-RT414 cassette face-and i cant figure out how to set up the time-cant find any instruction manuals on that either.
If anyone can help-THANK YOU!! even if you just tell me where to look online to find these things out would be a great help!
thanks!
Old Mar 26, 2002 | 04:23 PM
Blackened's Avatar
You don't know how to work an equalizer... wow....
Old Mar 26, 2002 | 04:36 PM
Jessica's Avatar
well-sorry-im not into audio stuff, so i dont know anything about it.
if anyone can actually HELP me-it would be very nice-thanks
Old Mar 26, 2002 | 05:14 PM
caleb's Avatar
Car: 89' Iroc
go to www.crutchfield.com they should be able to help you with the equalizer, and the cassette player
Old Mar 26, 2002 | 09:19 PM
bigt's Avatar
Re: equalizer help
I'm going on memory here since it has been 18 months since I've had a JVC head unit, but from what I remember you must turn the unit off (with the iginition on) and then hold down a button to be able to set the clock. Not sure which button that is. Play around with it a little and you should figure it out. Then you use the tuning buttons to set the time.
I also found the instructions for a new unit (probably similiar) here --> http://www.jvcmobile.com/pdfs/KS-F110J/en.pdf on page 13. It tells you to press and hold the "SEL" button, which sounds right.
Hope this helps.
Old Mar 27, 2002 | 10:26 AM
Jessica's Avatar
Thanks so much guys! it really helped!
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
novaderrik
Aug 10, 2015 12:44 PM
MikeS
Aug 17, 2001 05:09 PM
Trent257
Car Audio
Jul 14, 2001 11:54 PM
squirrelybird
Car Audio
Apr 2, 2001 06:34 PM
